This command is used for per port setting for the VLAN registration. If the global registration is forbidden, ports cannot be added to any VLAN dynamically irrespective of the per-port setting. So for ports to be registered, the global and the per-port setting both should be “normal”, which is the default value.
| mvrp | Multiple VLAN Registration Protocol. |
| tag | The 802.1Q VLAN ID. |
| vlan_tag | VLAN ID ranging from 1 to 4094; type=uint16_t"; range="[1,4094]". |
| ports | Ports. |
| port_list | Port list separated by a comma or -"; type="portlist_t"; |
| all | All ports. |
| registration | Whether port can be added dynamically to the VLAN. |
| forbidden | Port cannot be added dynamically to the VLAN. |
| normal | Port can be added dynamically to the VLAN. |
Normal.
Use this command to control dynamic addition of ports to VLANs.
configure mvrp tag 2 ports 2,3,4 registration forbidden configure mvrp tag 2 ports all registration normal
This command was first available in ExtremeXOS 15.3.
The registration option, and forbidden and normal keywords were added in 15.3.2.
